info on 350 straight
guy garrin
Post by guy garrin » Mon Oct 10, 2022 6:45 am
could you tell me what year and any info about this jd crawler o6oo35t t4f1c thank you very much
Re: info on 350 straight
Post by Jim B » Mon Oct 10, 2022 7:09 am
Here is the machine serial number tag breakdown using the 350 Introduction from the JD parts Catalog:
SN = serial number
T = Tractor
4 = JD350
F = Crawler - Dozer
1 = Gasoline
C = (Transmission) Sliding Gear
Serial number: 060035 (This number falls in the 1967 build range using the serial number list on this site’s FAQ board)
T= (Build location) John Deere Dubuque Works
This serial number is a 1967 straight 350 crawler dozer with a gasoline engine having a sliding gear transmission, without a reverser.
350 Introduction
Your posts for 350s, and later models, really should be on the Late Models Board. This post will likely get moved over there by a moderator.
Users browsing this forum: Google Adsense [Bot] and 200 guests
