Battery
Re: Battery
Just to be sure we are looking at the right 440, as the batteries were located in different places. The 440ICD was 12 volt and the battery was mounted in a box, on a fender in believe. The 440IC was 6 volt originally, with the battery mounted on the engine side of the instrument panel consol. The original 6 volt battery group was a Group 1. A Group 25 12-volt is close in dimensions. Are you asking about a 440ICD or is yours a 440IC that has been converted to 12 volts? And where is the battery mounted? What and where could make a difference in the answers.
This question would be better on the Early Models Board and may get moved over there.
