1010 air leak
Bret4207
1010 air leak
Post by Bret4207 » Wed Aug 24, 2022 5:27 pm
My 1010 crawler/loader/backhoe is sucking air. I found the o ring in the tank that goes on the standpipe by the filter was hard and leaking. I made a new one out 1/8" material and it seemed to solve the issue, until I got on a slight slope and then I get the air leak again. I can't tell if it's coming from the tank or elsewhere. I've tightened all the lines I can and the clamps on the suction lines. I'm concerned at this point that I either have a collapsed hose that joins some of the steel lines or I'm missing something obvious, like the o-ring I made out of 1/8" material is wrong.
Any ideas gratefully appreciated.
40C, 420C, 1010C-L-BH, Cat D4
Re: 1010 air leak
Post by Lavoy » Thu Aug 25, 2022 8:51 am
I might be misunderstanding, but I assume you are meaning on a fuel line? If there is fuel above the line, it can't be an air leak.
Bret4207
Re: 1010 air leak
Post by Bret4207 » Thu Aug 25, 2022 11:49 am
Sorry, I have a suction leak on my hydraulics. Bad enough that the pump is chattering whenever the loader or hoe is in operation.
Re: 1010 air leak
Post by Lavoy » Thu Aug 25, 2022 2:52 pm
That can be a tough one to find.
gus
Re: 1010 air leak
Post by gus » Thu Aug 25, 2022 4:20 pm
If it only happens on a slope, I would check the tank suction line. Over fill the tank to see if it changes anything.
Bret4207
Re: 1010 air leak
Post by Bret4207 » Sat Aug 27, 2022 7:16 am
Thanks Gus. I'm in the process of changing out the suction pipe hose unions now. The tank should be dry judging by the amount of oil I got all over me, so I'll pull the filter and check the standpipe. Already found a loose suction fitting but tightening made no difference. My fear is it's a crack in weld somewhere, that would be a needle in a haystack thing to find.
gus
Re: 1010 air leak
Post by gus » Sat Aug 27, 2022 8:42 am
Might try pressure in the suction line. It would force oil out of the leaky spot if it is in the line. Eliminate one thing at a time.
Bret4207
Re: 1010 air leak
Post by Bret4207 » Sun Aug 28, 2022 6:36 am
I'm pretty sure the leak is at the pump. Anyone ever tear into one of these?
gus
Re: 1010 air leak
Post by gus » Sun Aug 28, 2022 8:30 pm
Have you replaced the filter? Not quite the same but a plugged filter caused my vacuum pump to cavitate when transferring wine and caused it to pull in air.
Bret4207
Re: 1010 air leak
Post by Bret4207 » Mon Aug 29, 2022 6:38 am
Filter has maybe 2 hours run time on it. It's worth a shot though. Thanks!
Bret4207
Re: 1010 air leak
Post by Bret4207 » Tue Aug 30, 2022 7:08 am
Is there an aftermarket filter for this or am I stuck going back to mother Deere? I found a reference here to a Fram CH6484 filter being a cross referenced option but no one seems to have followed up and verified that. ???
Bret4207
Re: 1010 air leak
Post by Bret4207 » Fri Sep 23, 2022 2:56 pm
Gus, changed the filter. The old one only had a few hours run time on it, but so far it looks like you were right! No air leak so far. Haven't had a chance to work it, but it's better than it was for sure. Thanks!
