I have a great 1979 450C that has an intermittent low range on the HLR . Most times there is nothing when I shift to Low, but occasionally I get a surprise and the Low engages normally, until the next time, and then nothing.
Is there a spool valve or something that I can service that may be sticking?
I haven't checked any oil pressure yet as everything else seems to be bang on. Just the Low is not responding most of the time.
Ideas????
JD450C low range on HLR intermittent
Re: JD450C low range on HLR intermittent
Consider checking the linkage adjustment. Follow the H/L/R lever down to the battery box and along the transmission. There are adjustable joints there.
ND Phack,
Did you get your low gear problem fixed? If so, what was the problem? My crawler is acting up in low gear.
Thanks!
Thanks!
JD450C
