Guys, I've got so many questions about my new toy (350C) that I believe I can keep you busy for a while if you are willing. I haven't got a manual yet but I can see that I really need one. So I will just ask the ones I need answers to the most.
Two dipsticks in the floorboard: I assume the one under the air cleaner on the right is the transmission and the other at my left heel to be the reverser. How did I do?
I know John Deere has their brand of oil for that but can I use something else?
Also, what goes into the final drives?
Thanks guys,
Cuzz...
350C oils
350C oil
It's the other way around; the front one, under the air cleaner, is for the reverser, and the other one is for the transmission, steering clutch, and final drives. Everything on that machine, except for the engine, takes the same oil - JD20A or an equivalent trans/hydraulic oil.... any oil distributer can sell you the equivalent. The engine uses any series 3 diesel engine oil... there should be a lube and oil chart under the left armrest, but it's possible it got worn away over the years.
srs_mn
srs_mn
