Changing fluids in CLutch housing, Final drives
SkinnyPedal
Post by SkinnyPedal » Fri Mar 18, 2022 7:02 pm
let me start by asking, Please look over my ignorance. I am really new to the crawlers and JD.
I have a 1985 350c crawler/dozer
I have been changing all the fluids and filters. I have successfully change the engine oil and filter, fuel filter, reverser filter and fluid. I have drained the transmission, steer clutch housings, and finals drives with the 5 drain plugs per the manuals.
I have purchased the service manual, parts manual, and Operators manual but I just can't seem to find how to refill the transmission, steer clutch housing, and final drives. It says they hold 10 gallons and that close to what was removed.
I have put 5 gallon in thru the transmission dip stick tube. It appears that's not the way to get it all filled as it checks WAY over full now. I'm sure I am over looking the refill procedure for the clutch housings and final drives but I can't seem to find it anywhere in the manuals.
Please help
Thank you
Rick in East Tn
dtoots1
Re: Changing fluids in CLutch housing, Final drives
Post by dtoots1 » Sat Mar 19, 2022 8:21 am
Not sure on the 350s...my jd440 has a bung plug on opposite side of the tranny from the dipstick
SkinnyPedal
Post by SkinnyPedal » Sat Mar 19, 2022 10:32 am
Thanks, I'll check that out.
SkinnyPedal
Post by SkinnyPedal » Sat Mar 19, 2022 11:04 am
I think I found the answer with a google search. Prolly should have tried that first. lol
http://www.jdcrawlers.com/messageboard/ ... php?t=8751
Hopefully will help with someone else search.
Rick
