65 jd crawler
dennisg
65 jd crawler
Post by dennisg » Thu Mar 17, 2022 6:35 pm
Bust inlet fitting out on hyd pump. Would like to find a replacement back plate that the had good inlet ant outlet fitting
dennisg
Re: 65 jd crawler
Post by dennisg » Thu Mar 17, 2022 6:46 pm
Info on pump B24307 LD CB 9 spline clock wise any place get used replacement pump
Re: 65 jd crawler
Post by Jim B » Fri Mar 18, 2022 8:50 am
Welcome to the board.
Several different pumps were used in different models. It would help to know the crawler, 350 or 450, dozer or loader, and pump size. The number you have posted isn't a JD part number for anything I can find.
Jim
Users browsing this forum: Majestic-12 [Bot] and 179 guests
