Winch for a 350C question...
Cuzz
Post by Cuzz » Fri Jan 19, 2007 8:10 pm
First off, I'm the new kid on the block and I can't believe how much good information is here.
I just aquired a 350C and I would really like to put a winch on it. What winches will fit? I do know about the 8a Gearmatic but are there any others... ?
Cuzz...
JD430C
Post by JD430C » Fri Jan 19, 2007 9:34 pm
hi cuzz, jd model 3310 and 3315 winches were offered for the 350s, but a jd 10 series winch will fit. i dont think a gearmatic 8a will fit. i do know where there is a jd 10 winch if interested.
andrew
Cuzz
Post by Cuzz » Fri Jan 19, 2007 9:58 pm
What can you tell me about the JD 10? Good line pull? How much cable and size? Just anything interesting would be great...
JD430C
Post by JD430C » Sat Jan 20, 2007 12:25 am
hi, the book lists the 3310 as having 10,600lb bare drum line pull, full at 6,650lb. it will hold 195ft of 1/2 cable and 125ft of 5/8 cable. the 10 series winch and the 3310 are pretty much the same. came control, same case, and i think most of the inside stuff is the same. we had a jd 10 on a 1010 and i put one on a 350, seemed to pull good, but u have to use them at least once a month to keep the bands from sticking to the drum.
andrew
