Looking for JD 350 steering clutch housing
mc_mike
Post by mc_mike » Sun Dec 26, 2021 3:05 pm
Anyone know where I can get a right side steering clutch housing for a straight 350 Mine is severely cracked.
Re: Looking for JD 350 steering clutch housing
Post by Jim B » Wed Dec 29, 2021 2:09 pm
Have you checked with Lavoy? Have you called any salvage yards? You may want to have your crawler serial number and the casting number that is on your housing in hand. The parts catalog shows a serial number break with two different ones used. I don't remember of hand the difference and am not sure they will interchange. It may have to do with some having different holes for attachments.
Here is a link to the online parts catalog. https://partscatalog.deere.com/jdrc/nav ... ment/62257
Post by Lavoy » Thu Dec 30, 2021 8:24 am
I do not have one, I will check with a buddy to see if he has one.
Garymcd
Post by Garymcd » Fri Dec 31, 2021 5:09 am
Will one off a 450 fit it?
Post by Jim B » Fri Dec 31, 2021 5:56 am
No, a 450 housing will not fit a 350.
Garymcd
Post by Garymcd » Fri Dec 31, 2021 6:26 am
Ok. I have a 450 parts dozer and was going to hook you up but dang the luck.
NWJD fan
Post by NWJD fan » Fri Jan 07, 2022 1:56 pm
Try Mark in Johnson Vermont. He used to post here as pondhogvt and regularly has listings in Vermont craigslist in heavy duty equipment for 350 and 450 parts. He had 350C steering clutch housings a couple of years back.
Users browsing this forum: No registered users and 145 guests
