Hello All,
I want to clean the HLR transmission filter and check condition.
I have read several posts on this and did not see how to remove the cover.
I have drained the oil, removed the 3 bolts that seem to hold the filter cover on.
I do not really see what to pry on to get it to come loose, I am trying not to break anything. I have tapped on the cover, and tried to pry but no luck.
Any suggestions?
Larry
JD450 H-L-R transmission filters
Mikeforester
- 420 crawler
Re: JD450 H-L-R transmission filters
Hi Larry,
Try working a small thin chisel between the cover and the case and it will come off. It is probably stuck on due to the gasket and sealant being old.
Mike
Mike
Thank you,
that was what I thought but thought I should ask before doing something stupid.
