jd 450 ignition switch
- 40C crawler
My JD450 has an open and close switch and a start button,I want to keep the start button but install an ignition switch with a key,do I need a switch 24volt because I have 2 12volt batteries or will a 12volt do the job Thanks Bearchopper
Re: jd 450 ignition switch
Your two 12 volt batteries should be wired in a parallel configuration. So stay with a 12 volt switch.
Best regards, Bruce
Best regards, Bruce
- 40C crawler
Thank you Mr B Town I will stay with my 12volt ignition switch Bearchopper
Users browsing this forum: No registered users and 240 guests
