fuse panel on jd 450 1965
bearchopper
- 40C crawler
Thank you on your help on my last question ,now I would like to know if there is a fuse box on this dozer and where is it Thanks Bearchopper
Re: fuse panel on jd 450 1965
No fuse box, there should be one circuit breaker behind the dash panel.
If you don't have the manuals you should get a set, at least the service and operator's manuals. Lavoy can likely help you with getting them through his store. You can use the on line parts catalogs at jdparts.com.
Here is a link to the crawler parts catalog: https://partscatalog.deere.com/jdrc/nav ... ment/64777
And here is the loader parts catalog: https://partscatalog.deere.com/jdrc/nav ... ment/65555
bearchopper
- 40C crawler
Thanks for your assistance,I have the manual and operation but I did not see anything about the fuses Bear chopper
