1957 420C seized - photo journey
emmett
Post by emmett » Thu Aug 19, 2021 9:18 am
I've had this beast since 2004 and it has served me well.
Had to rebuild one final drive, but otherwise no big projects required.
Unseen oil leak while running the winch for a few hours lead to a seized engine.
I'm in the process of rebuild.
Thought I'd add some photos.
ENGINE OUT!
420C Crawler 1957 w/ blade & army 6x6 winch
bscrawler
Re: 1957 420C seized - photo journey
Post by bscrawler » Thu Aug 19, 2021 10:33 am
Nice to see a few of your pictures during this rebuild journey .
emmett
Post by emmett » Thu Aug 19, 2021 3:46 pm
Yeah, but I forgot how to post photos on this site!
I'm trying to link to my photos on imgur, but no luck.
Post by Stan Disbrow » Fri Aug 20, 2021 4:45 am
Post by Lavoy » Fri Aug 20, 2021 8:36 am
You have to use the direct link or embed code I believe, assuming it is like imgbb.
emmett
Post by emmett » Sat Aug 21, 2021 4:00 am
Next I have pressure washed the outside of the block (oil pan still attached).
emmett
Post by emmett » Sat Aug 21, 2021 4:06 am
OK, I've pulled the oil pan off and inverted the engine on the stand.
Next step is to unbolt the connecting rod caps and see which of the two cylinders is seized.
It's gonna be fun.....
emmett
Post by emmett » Sat Aug 21, 2021 7:43 am
Feeling very lucky.
Pistons came out easy.
Looks like the innards here have been visited before.
There are very nice machinist's markings on the crank and only one of the rod caps had the locking nuts installed.
Journal bearing (is that correct enough terminology?) for #2 is cooked.
See photo to see how the contact surface smeared. See the inside of the cap I placed below the crank shaft.
It transferred some of the alloy onto the crank surface.
I'm gonna get new pistons, rings, and crank bearings.
Gasket kit, oil seals.
Anything else while I'm here?
Next step is to punch the dowel-pin out of the crank pully and dig the crank out.
Buckhorn
Post by Buckhorn » Sat Aug 21, 2021 9:17 am
Put the coffee on, and I'll come watch you. Not sure where you are in VT, but I live there too.
I can always learn something.
Pete
Post by Jim B » Sat Aug 21, 2021 4:47 pm
I would suggest letting the machine shop you have recondition the crank, get the bearings and to keep any related issues in their court.
Post by Lavoy » Sat Aug 21, 2021 8:09 pm
Sadly right now main bearings are out of stock nationwide. I can get rod bearings, but likely not mains.
bscrawler
Post by bscrawler » Sun Aug 22, 2021 3:50 pm
I recently purchased a 420 . So I’m following closely what you are getting into. Thanks for posting
emmett
Post by emmett » Mon Aug 23, 2021 2:26 pm
Hi Lavoy,
Full parts list coming by tomorrow.
With more photos.
This engine has been rebuilt before, as the crank journals are undersized.
It was really well done, surfaces are perfect and within 0.001 tolerance.
Fortunately, I don't have to send anything out for machining, I can reface the valves and hone the cylinders myself.
I got lucky 'cause there is no ridge built up on the cylinder tops.
I'll try to source the main bearings elsewhere, but I'm gonna need the rod bearings for 0.040 undersized crank rod journals.
It's the rod bearings that melted onto the journals when oil starved.
FYI, The main journals are 0.010 undersized.
Will also want two new pistons w/ pins and clips for 113 cc engine (4.250 diameter cylinder bores)
I'll also need one intake valve (one is slightly bent).
New clutch plate (why not?), throw-out bearing and pilot bearing (while its broke apart anyway).
Emmett
emmett
Post by emmett » Tue Aug 24, 2021 5:36 am
My very good and very smart friend has an engine shop.
I dropped the block w/ engine stand and head in my rig and drove it all over.
A good day's work and we had it disassembled, measured, cleaned up, valves resurfaced, and cylinders honed.
Some photos follow.
emmett
Post by emmett » Tue Aug 24, 2021 5:38 am
Block is inverted on the stand.
Cylinders honed nicely. I was lucky, no ridge built up on the cylinder tops.
Camshaft is in good shape. Turns freely. We decided to leave it be.
Users browsing this forum: Google Adsense [Bot] and 27 guests
