420c s/n 100676 FINAL DRIVE
allenjohn
Post by allenjohn » Thu May 27, 2021 8:25 am
WHEN INSTALLING A NEW BRAKE BAND. WHY IS IT SO TIGHT BETWEEN THE HOUSING DOWLE PIN ON THE LOWER RIGHT SIDE AND THE BRAKE DRUM. ( CAN'T TURN AT ALL BY HAND ? ) MAKE ALL ADJUSTMENTS BEFOR PUTING THE RIGHT SIDE FINAL DRIVE BACK IN PLACE PLEASE HELP THANKS !
dtoots1
Re: 420c s/n 100676 FINAL DRIVE
Post by dtoots1 » Thu May 27, 2021 8:32 am
if similar to my jd440ic you will probably have to adjust brake band a bit tighter or even looser to get clearance for drum and the housing, is real close tolerance for clearance.
allenjohn
Post by allenjohn » Thu May 27, 2021 11:40 am
THANKS DTOOTSL 1 I GIVE IT A SHOT SEE HOW IT GO'S
