Idler adjusting tube
Swanybawanie
Post by Swanybawanie » Tue May 18, 2021 4:45 pm
Hello friends,
I have one idler adjusting tube that is locked good, won’t twist, won’t pull apart, took it to an industrial shop tried twisting it with a 36” pipe wrench, no go. All the screws are out of it, soaked in penetrating oil, it’s still at the shop, the guy that does the job is busy on a job and really hasn’t had a complete attention on it, he says he will. What do you suggest? Heat up the outer cylinder? The tube is locked in an almost complete extended position. Hope this helps, what do you think should be done to it?
Re: Idler adjusting tube
Post by Lavoy » Wed May 19, 2021 1:07 pm
I assume you mean a mechanical adjuster, not hyd? If so, throw it in a barrel of water for a couple weeks, but even then, doubt it will go.
timr
Post by timr » Fri May 21, 2021 10:13 pm
Edited Because Lavoy knows his stuff :) it was rough but i kept pumping grease into mine and it did come out was just so hard because of all the dirt that was packed down in it..... thanks once again Lavoy :)
Users browsing this forum: No registered users and 56 guests
