steering clutch adjustment
- gregjo1948
Working on a JD 350B. After installing new steering clutch discs, I need to adjust the pressure plate fingers and I wondered if the adjustment gauge, that I purchased to adjust the pressure plate fingers on a JD 1010, would work for the JD350B???? thanks, gregjo1948
Re: steering clutch adjustment
I think the JD7 gauge works for the 350B steering clutches, but I don't have a manual to confirm that. A search of past posts indicates it is the one people were using. Lavoy, LeonardL, or others will be along to confirm or correct my thought.
Jim
Jim
Same gauge, correct.
Users browsing this forum: No registered users and 73 guests
