I have the chance to buy this winch for 1000$ and the log arch for 500$ I have a 350b loader. Is the winch missing anything to make operate? Is this a decent price? I keep seeing stuff about a control valve but I’m not sure if it’s on this or not. Thankyou
https://www.facebook.com/marketplace/it ... 056109010/
3315 winch question
Trucksareford42
Re: 3315 winch question
Good morning,
First, prices vary from region. But I can tell you the log arch is nearly worth the entire asking price in the Midwest.
If you did not see the winch work, consider it to need work/rebuild. The winch in the link has the suspect square type rotary valve( it is the small square control valve on the crawler side of the winch with the hydraulic hose from the filter). At one time, there were no parts to rebuild that valve, which had a notorious reputation. I am not certain, but the parts to rebuild may now be available. Regardless the arch is definitely valuable. And the winch has value, even if for parts. I see it has the control lever and cable. Looks like it is complete bolt on ready for a 350.
You will need to confirm your machine has a winch drive. If your machine does not, you should negotiate buying the winch that was coupled with the winch.
https://partscatalog.deere.com/jdrc/sid ... gId/182801
The coupler is present on the front of the winch input shaft, another necessary item.
Upon closer look, the winch on the pallet doesn’t appear to be the same one mounted on the crawler with the arch. The paint on the left quill case is different and the cable is different. Just saying, may not make a difference
Best regards, Bruce
Best regards, Bruce
Trucksareford42
Thankyou so much for the info Bruce
I agree with Bruce that it looks like two different winches. Or the pictures were taken years apart.
It looks to me like the control cable is broken. Part of it is visible connected to the rotary valve with a tail hanging out on the right side of the winch.
Does your crawler have the power shaft to drive a winch already installed? If not you will need to do that.
Jim
Jim
