JD 550G Trunnion Ball / Blade Pivot
darrenrudolph83
Post by darrenrudolph83 » Mon Apr 05, 2021 9:22 am
Good morning!
Looking for some info on the 550G trunnion, mine is fairly sloppy and will need to be repaired or replaced soon. I am assuming the ball itself is welded in? Are the balls made of a harder steel then the cap? I am wondering if in general a guy could purchase a new cap, remove any shims if any are installed to tighten up the cap/ball assembly. If the ball is welded in then its going to be difficult for me to do because the machine is located at my remote cabin and unfortunately I do not have a welder capable of a job like that just yet.
Thank you in advance for any help or suggestions on field repairing this well enough for another summers use.
LeonardL
Re: JD 550G Trunnion Ball / Blade Pivot
Post by LeonardL » Mon Apr 05, 2021 6:21 pm
The balls are replaceable but as you pointed out it isn't an easy task. I have done a few of them over the years and had them removed by our fabrication shop that had air arc equipment to remove the worn ball. The caps are hardened but I have no idea if they are as hard as the ball itself. There are shims that you can remove if haven't done so already. You can add a new cap and tighten the slack up a little but not much. The best fix is to replace all of the pivot mechanism.
darrenrudolph83
Post by darrenrudolph83 » Tue Apr 06, 2021 7:04 am
LeonardL wrote: ↑
Thank you LeonardL,
That is what I was afraid of, I suppose the best thing to do will be wait for summer until I am able to get back out to where the dozer and and remove the cap. I am fairly certain from last summer the ball is nearing end of life.
