JD350 Injectors
stevenx40
JD350 Injectors
Post by stevenx40 » Sun Feb 21, 2021 8:21 am
Hello again, Well after searching for new replacement 9.5mm pencil injectors for my 1969 , all that i find have a fixed threaded fitting attached to the injector side. My originals have a swivel fitting on the injector side and the fuel line side is fixed in place. The part number on the original injector is 17579J5. So are my choices , maybe find original style so as not to play with fuel lines, try to adapt new ends on fuel lines to match up with newer style injectors, possibly have old ones refurbished ( don't like that option ) . I also noticed that originals were calibrated to 3000 psi after market are set to 3200 psi not sure how much of an effect this would cause on performance and accelerated wear on injection pump. Any thoughts ! Steve
LeonardL
Re: JD350 Injectors
Post by LeonardL » Sun Feb 21, 2021 9:30 am
Check with Lavoy on this. I think he will be able to fix you up. Otherwise any good Deere dealer should be able to find what you need.
stevenx40
Re: JD350 Injectors
Post by stevenx40 » Mon Feb 22, 2021 7:17 am
I found the Error in my thinking, the nuts were just rusted solid after 52 years, all is well. Steve
LeonardL
Re: JD350 Injectors
Post by LeonardL » Mon Feb 22, 2021 6:29 pm
Glad you figured it out. :D
