350 Injector Removal
stevenx40
Post by stevenx40 » Mon Feb 15, 2021 7:32 am
Hello all, In anticipation for removal and replacement of my 52 year old 1969 JD350 injectors i have read most of the post. I was wondering if i were to loosen the hold down nuts on each injector about 1/8" and try starting the motor that they would start to move the injector just enough to break it free for easier complete removal. Is it a worthwhile task or will the struggle be hard all the way out. I would appreciate your thoughts. Steve
Re: 350 Injector Removal
Post by Lavoy » Mon Feb 15, 2021 9:20 am
I would not do that. Soak them in your favorite weasel piss and just try to pull them out.
LeonardL
Post by LeonardL » Mon Feb 15, 2021 10:03 am
I agree with Lavoy on this. If you plan to replace them anyway then they aren't sacred. If I think they are going to be tight I soak them and then use a pry bar or a hammer and punch to loosen them. Pry them laterally or turn them from side to side to loosen them. Then they will pry up and out pretty easily.
stevenx40
Post by stevenx40 » Thu Feb 18, 2021 6:38 am
Thank You both, after repeated soaking for three days they came right by hand, amazing . Steve
Post by Lavoy » Thu Feb 18, 2021 8:01 am
I would anti-seize the new ones before putting them back in.
jsal
Post by jsal » Thu Feb 18, 2021 8:27 am
there is a small slide hammer that I bought to remove pencil injectors because the first set I took of my 66 350 I ended up destroying the injectors using pry bars believe I purchased on Amazon OTC also makes one much easier
JIM
