stmftr395
Post
by stmftr395 » Fri Dec 29, 2006 8:04 pm
Can a 350 upper idler be used with a 1010 track and carrier? Mark
- Site Admin
Post
by Lavoy » Fri Dec 29, 2006 9:40 pm
Only if you change over to 350 idler supports.
stmftr395
Post
by stmftr395 » Mon Jan 01, 2007 8:46 pm
I can use the 350 upper idler and supports bolted to the 1010 carriers? Mark
- Site Admin
Post
by Lavoy » Mon Jan 01, 2007 11:16 pm
Mark,
They should bolt right on then you can use the 350 style roller, shaft and seal.
If you find a support, I have a new 350 upper idler on hand with shaft.
stmftr395
Post
by stmftr395 » Tue Jan 02, 2007 11:22 am
Lavoy; Yes I believe I can obtain the 350 supports(I need to replace both). Do you feel this is the best way to approach the situation or should I try to repair/replace the 1010 parts? What is your availablity for 1010 components? Mark.
Users browsing this forum: No registered users and 215 guests
