Track chains
Track chains
Sort of researching 1010 replacements, came across this. Anyone know anything about them or the comapnay?
40C, 420C, 1010C-L-BH, Cat D4
Re: Track chains
No link shows, but there are no direct replacements, anything new will require sprocket rims.
Re: Track chains
I'll try again. https://rubbertracksandattachments.com/ ... -set-of-2/ So these wouldn't be correct? A sprocket rim wouldn't be the end of the world. I assume they are probably 350 tracks?
Re: Track chains
No, in spite of what the add says, those are 350 chains. New 1010 chains do not exist, haven't for as long as I have been at this. Those will work, you will need to purchase a set of 350 sprockets, cut the rim off of them and yours, and weld the new rim on your old centers.
Re: Track chains
Lavoy, looking at my drive sprockets I can see the rims appear to have been welded already. Is there a way to determine if they've been switched to 350 rings already? Couldn't find anything in a search here.
Re: Track chains
If you have a piece of 1 3/4" OD tubing, set it in one of the cups and see if it sets in there all the way to the bottom.
Re: Track chains
Yes, 1010 are 1 9/16".
Users browsing this forum: Google Adsense [Bot] and 208 guests
