Engine
Charlie
Engine
Post by Charlie » Thu Sep 24, 2020 1:38 am
Where is the engine oil pressure sending unit located on the engine?
I have looked in all 3 manuals I have and can't locate it
Charlie.
I have uploaded some pictures, with more to follow
gregjo1948
Re: Engine
Post by gregjo1948 » Thu Sep 24, 2020 2:22 am
I don't see any pictures. What model machine do you have? If it's a 420, I think it would be right by the oil filter.
Re: Engine
Post by Jim B » Thu Sep 24, 2020 4:18 am
Good morning Charlie.
I am guessing this may be your 450C loader from your past posts and pictures I see on the picture server from a Charlie 3933. Look at the rear of the engine kind of behind the fuel filter and drive end of the starter, in the housing plate at the right rear of the engine block.
It helps folks if you include what you are working on in your post. Did you intend for the pictures to be in this post? If so did you use the picture icon when you typed your post and copy the info of the picture from the picture server and paste your pictures' info into your post? If you want readers to go to the picture server, to see your pictures, you should say that and the name of your gallery. Here is a link to what I believe is your gallery to help the guys get there. http://jdcrawlers.lcent.com:8000/johnde ... ?cat=10048
The picture server, and using it, seems a bit difficult at first but not bad after a few uses. dtoots1 is one who can give you pointers. You might want to PM him if you're interested.
Hope this helps.
Jim
Charlie
Re: Engine
Post by Charlie » Sat Sep 26, 2020 7:03 pm
Charlie3939 is me.
Hopefully I'll get better
