Hey everyone,
Is there a reference sheet somewhere on like parts? I have a 350C, but have found 450 parts machines more often than the 350's. Don't know how worth my while it would be.
Any input from the pro's would be greatly appreciated.
Thanks for reading.
350 vs 450 swap-compatible parts list
AddamsonFlint
- 420 crawler
Re: 350 vs 450 swap-compatible parts list
There isn't much between the two machines that will interchange. The 450 is a much larger machine that the 350 and the 450 has a four cylinder engine where the 350 has a three cylinder. Sorry but other than some very small parts there isn't much that will work between the two.
The short answer is no. If you have a 350, you need a 350, as well as probably the same series.
