Starter
Swanybawanie
Starter
Post by Swanybawanie » Sun Jun 07, 2020 7:41 pm
My starter on the JD 440IC has a broken off ear on one of the bolt holes, what do you do? Have it welded? Put a piece of steel behind it shaved to the shape of the curve of the starter with a hole drilled for support?
gregjo1948
Re: Starter
Post by gregjo1948 » Mon Jun 08, 2020 2:47 am
Try going to your local rebuilder to see if he can solve the problem correctly, before you end up stranded far from home in a mud hole and the starter is failing you. You could also check with Lavoy. (Owner of this site.)
Re: Starter
Post by Lavoy » Mon Jun 08, 2020 8:03 am
No nose cones available any more other than used. I might have a used one, would have to do some digging.
Swanybawanie
Re: Starter
Post by Swanybawanie » Mon Jun 08, 2020 8:46 am
Nose cone? What’s that?
Also the starter is missing the top cover of some sort, where the brushes are located, is there a cover available?
Re: Starter
Post by Lavoy » Mon Jun 08, 2020 8:53 am
The part with the bolt holes.
Yes, I have new cover bands in stock.
Users browsing this forum: No registered users and 245 guests
