440 gas loader coming apart
smitty906
Post by smitty906 » Sun Jun 07, 2020 8:20 am
Just picked up a parts machine in pieces
Have a model 91 loader complete with cylinders $500
I am going to keep the drivetrain , will be adding other items soon.
Located in upper Michigan.
Message me if you are looking for something in particular
Josey
Re: 440 gas loader coming apart
Post by Josey » Wed Jun 17, 2020 1:17 am
Got any backhoe hooks? I’m in Minneapolis and have a 440ic, it has a PTO shaft without any lifting arms. I don’t know what it was for but it works. I wish there would be a threshing show this year so I could meet some folks that have one of these things.
Josey
Minneapolis, MN
440ic Rookie
smitty906
Post by smitty906 » Fri Jun 19, 2020 6:19 am
Sorry no hooks or 3 point parts.
jkemp43
Post by jkemp43 » Fri Nov 13, 2020 2:38 pm
How about track rollers do you have any of those?
smitty906
Post by smitty906 » Sat Nov 14, 2020 6:43 am
I just replaced one side completely on my dozer and i think there was 1 possibly 2 shell useable , if i remember correctly there were 3 with good pins and bushings no play , but the shells were shot. a guy could put one together if he needed one. The parts machine i would have to check the condition probably in the spring.
smitty906
Post by smitty906 » Sat Nov 14, 2020 6:55 am
Also have other parts available ......Hood and front nose frame with grill,
fuel tank , loader assembly with cylinders , counterweights with mounting bracket . Deluxe seat frame , hydraulic pump .
dtoots1
Post by dtoots1 » Sat Nov 14, 2020 3:16 pm
and which hydraulic pump would that be?
smitty906
Post by smitty906 » Mon Jun 03, 2024 6:20 pm
Complete 91 loader for sale ......other parts available .
Michigan / Wisconsin border
dtoots1
Post by dtoots1 » Mon Jun 10, 2024 9:12 am
need name of pump and operating valves...may need once i get mains and try mine...assume is crank pump not cam pump?
smitty906
Post by smitty906 » Sun Jun 16, 2024 8:53 am
Yes it is a crank style pump I believe , it's different than my cam pump on 440 dozer.
Should have everything you need.
dtoots1
Post by dtoots1 » Fri Jun 21, 2024 1:10 pm
Am still waiting on main bearings for my 420....do you have name of the pump and valves??? Hydreco?
