What to do with backhoe hyd. hoses?
Just wondering if i connect the hydraulic lines together at the back after I disconnect the backhoe attachment or leave them disconnected? Thanks
Re: What to do with backhoe hyd. hoses?
Hook them together I believe. On the ones without a diverter valve, it dead head the flow, and the engine won't start, or it breaks the hyd pump.
Laovy
Laovy
Would it do any harm connecting them together if it does have a diverter valve?
No, won't hurt anything. If you open the valve, you will not have hyd for the loader, but won't hurt anything.
So am I right to say that if I connect the hoses and the loader doesn't work then it has a bypass valve and the lines need to be left disconnected?
