My 1500 dollar 440IC
wrenchead
Post by wrenchead » Wed Dec 20, 2006 8:04 pm
Well here's my new toy, cost me $1500 dollars and a few bucks in gas to haul her home. My 1 ton Dodge hauls her real well and this is a plus!!
Started to tear her down a few days ago. Got the blade off and one of the tracks which are badly worn. I will post more as I go. :D
hunter41mag
Post by hunter41mag » Thu Dec 21, 2006 4:19 pm
Wrenchhead,
Congrats on purchase of your 440IC. Looks like most of it is there and the price was right. I also have a 440IC with 602 blade, 4 speed, no reverser, had a inopertive winch so I removed and added pto, sprocket shields, deluxe seat, hr meter, dual hydraulic control. According to serial # and chart on this website mine is a 1960 vintage.
Does yours have the following:
reverser?
pto?
4 speed or 5 speed?
daul or single hydraulic control?
Don
Eastern PA
440IC
wrenchead
Blade Supports
Post by wrenchead » Thu Dec 21, 2006 4:55 pm
Here's a photo of the hack job done on the track frames. The bolts broke so they took and welded the blade supports onto the track frames.
I guess this whole project will take longer than I thought.
And notice the bent up, or should I say DOWN! Track tensioner spring.
And thank GOD for Crawler Heaven and Lavoy!!!
Don, Yes I have a PTO but no 3pt, I'm looking for one but the funds and wife will have to permit.
Same goes for the reverser sure wish My 440 had one.
I'm not sure of the number on my blade but I think it's a 602.
I have a 4 speed tranny.
And she is a singleton on the Hydraulic control valve.
She is a 1958 early model 440IC and the ser# is 441958
looks like I'll never foget the year because it wound up right in the serial #
More posts coming soon!!! :!: :D
Brian E.
wrenchead
Track Tensioner Sping a closer look
Post by wrenchead » Thu Dec 21, 2006 8:46 pm
Well here's a closer look at the somewhat cresent shaped track tension spring. I didn't notice it until I took the cover off it and pressure washed the six inches of dirt out of it. I got one coming from Crawler Heaven :D
wrenchead
Its going to take some work to fix this.
Post by wrenchead » Thu Dec 21, 2006 9:07 pm
Here's a pic showing the torn out metal on the Right Track Frame.
I looks like the blade support loosened up at one point in time and whoever owned the old girl just kept pushing dirt. And then broke out the arc welder to keep her running.
wrenchead
Right Track off
Post by wrenchead » Thu Dec 21, 2006 9:32 pm
:mrgreen: Smiley face for the day :!: The right track is off.
Brian E.
1958 JD440IC
In central VT
lastchancegarage
Post by lastchancegarage » Tue Jan 16, 2007 4:28 pm
Brian,
It looks like you have your work cut out for you (no pun intended). By the way, what's the lever on the right side of the console? Was that hooked up to the reverser at some point? Do you not have a reverser or is it not operational? Just curious. Good luck as you go.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
JimAnderson
440ic
Post by JimAnderson » Tue Jan 16, 2007 8:39 pm
Brian,
Nice score.Looks like someone put 40c sprockets on it at one time.That
is not surprising.Between their age and the abuse that these things have
seen it is amazing any of them are even around for us to fool with. Good
luck.JimAnderson
Users browsing this forum: No registered users and 444 guests
