How do I tell year and make of my crawler?
Good afternoon. I recently purchased a crawler and I'm trying to figure out the year and actual model. The previous owner said it was a 1969 2010C but I'm not sure that's right. The numbers I have located on the block are T14886. And T17310T 1. It gas engine. The pictures I pull up seem to look more like a 1010. Thanks in advance for any help given.
Re: How do I tell year and make of my crawler?
Serial number is on the RH front corner of the engine block, or on the LH side of the bellhousing.
The numbers you posted appear to be casting numbers. T17310 comes up as a 2010 water manifold, which it may or may not be. If the number is raised and part of a casting it is just that, a casting number, often not even the part number. The 2010 series serial number is stamped on a metal tag usually located on the right side of the engine block. It should begin 2010C followed by the digits of the unit's serial number. A 1010 will begin with 1010C, then the number. The 1010s and 2010s wheeled and crawlers shared the same yearly serial number ranges.
Thanks. I found it. And as I suspected it's a 1010 C. Serial number is 26250
I think 26250 falls in the 1962 build range.
Ok. Great thanks for the help.
Users browsing this forum: No registered users and 281 guests
