350b hydraulic control valve
1968camaor
Post by 1968camaor » Wed Apr 08, 2020 6:11 pm
My hydraulic control valve for the 6 way blade is leaking out of the top. Anyone know where to find parts to rebuild these. I see a 2753 number on the side of it
Re: 350b hydraulic control valve
Post by Jim B » Wed Apr 08, 2020 6:58 pm
Welcome to the board. First place to check is with Lavoy (postmaster@jdcrawlers.com). He sells parts for JD crawlers in his shop, which provides this site for us to use. He maybe able to help you with what you need. If you don't have manuals for your machine he can likely help you with those as well.
1968camaor
Post by 1968camaor » Thu Apr 09, 2020 3:39 am
Thanks. I have all the manuals but can’t find anything on the parts for the valve.
Post by Jim B » Thu Apr 09, 2020 5:03 am
Are the Manuals you have all for a 350B? Publisher and manual number? It sounds like your 350B has a full hydraulic 6 way blade, which should be an inside mount. If so that would be a model 6305 blade. It has a separate parts manual from the tractor. Starting with the 350Cs they included the blades and other attachments in the crawler parts catalog. The valves and hydraulics for the blade are in that manual. Here is a link to the on line JD parts catalog #PC916 to the 6305 blade. https://partscatalog.deere.com/jdrc/nav ... ment/77969
1968camaor
Post by 1968camaor » Thu Apr 09, 2020 5:42 am
Yes the manuals I have are all just for the 350B, but what you sent me makes sense and helps. Thank you very much. Hopefully parts are still available for it.
Post by Jim B » Thu Apr 09, 2020 6:24 am
Look at the parts catalog, then it maybe worth a phone call to Lavoy. He often has sources for parts that help guys out. His business phone number is on the homepage.
You might consider adding your general location to your profile. Sometimes it is helpful to know about where someone is when suggesting sources or maybe even being able to give a helping hand.
Users browsing this forum: LeonardL and 17 guests
