Lindeman Oil Seals
judd
Lindeman Oil Seals
Post by judd » Thu Mar 12, 2020 7:12 am
Interested in speaking with someone who has replaced oil seals between transmission and clutch housing and clutch housing and final drive. Thanks.
Re: Lindeman Oil Seals
Post by Jim B » Thu Mar 12, 2020 7:55 am
You might start with giving Lavoy a call, 701-361-1006
Post by Lavoy » Thu Mar 12, 2020 8:47 am
I have not done them, but can't be too difficult. I would assume same process for the most part as the later crawlers. Remove final etc.
judd
Post by judd » Thu Mar 12, 2020 10:05 am
Thanks Lavoy, If I have to do the transmission side, do you know if the clutch housing has to be removed to get to the seal?
Post by Lavoy » Thu Mar 12, 2020 1:25 pm
I'm assuming not, but not positive.
B Town
Post by B Town » Thu Mar 12, 2020 2:01 pm
Are you talking about replacing the gasket behind the first gear reduction case? If so, yes the belt pulley and clutch comes off
judd
Post by judd » Thu Mar 12, 2020 6:10 pm
No, the seal between transmission and steering clutch housing.
Does the housing need to be removed or just the clutch pack?
Users browsing this forum: No registered users and 190 guests
