- Site Admin
Post
by Lavoy » Sun Mar 08, 2020 9:43 am
1010 gas above 21,000 give or take.
Owner and moderator
www.jdcrawlers.com
wvcharlie
Post
by wvcharlie » Sun Mar 08, 2020 10:04 pm
Lavoy, thank you so much. I’m looking at the serial number but I can’t figure out what year it is. I was surprised it is a 1010 and it’s worth more than I expected!
gregjo1948
Post
by gregjo1948 » Mon Mar 09, 2020 2:32 am
Lavoy wrote: ↑Sun Mar 08, 2020 9:43 am
I believe the 1010 part is correct but 21,000 seems way too high. Maybe I 'm not understanding. Around here, 1010s can be bought from 2000 and up.
Post
by Jim B » Mon Mar 09, 2020 4:38 am
Guys,
I think Lavoy's 21,000 was referring to an approximate serial number range not a value. I have seen 1010s priced from $1000 to $5000. What they actually sold for would be the real story. There is a post on the FAQ board with 1010 serial numbers and years. 21,000 would be in the 1961-1962 range.
wvcharlie,
You posted you were looking at the serial number but couldn't figure out the year. What is the serial number? The number you posted a picture of is only a component casting number, not the serial number. The serial number would be on a tag riveted to the machine. On the 1010s the tags were riveted to the block, on a flat spot, near the engine oil filter. The machine serial number should be preceded by 1010C on the tag. There might also be an A or I with the C to designate Agricultural or Industrial series.
Jim
- Site Admin
Post
by Lavoy » Mon Mar 09, 2020 9:02 am
Yeah, sorry, above 21,000 serial number.
As far as value, single hyd machine, pins and bushings look to be shot, no reverser, $1500-$3000.
Owner and moderator
www.jdcrawlers.com
Users browsing this forum: No registered users and 184 guests
