440 ic diesel
440 ic diesel
I have found a running wreck of a 440 ic but a diesel, the one I have is a gas, 1958 by serial #, is the engine clutch the same- gas or diesel? Trans- or is all diesels 5 spd? Are any of the drive line parts heavy- duty, because of the diesel- S. clutches or brakes and finals?
Re: 440 ic diesel
Trans is different than yours, not a direct replacement. All crawler after the diesel came out have the larger transmission, but there is not backwards compatibility due to side frame difference, bolt diameter and such from the earlier gas crawlers.
Re: 440 ic diesel
Tks. How about finals?
Re: 440 ic diesel
Finals are a serial number affair, no difference in case related to diesel.
Users browsing this forum: No registered users and 178 guests
