Oil pump fitting size for pressure line 40c
Fredquebec
Post by Fredquebec » Sat Feb 15, 2020 4:19 pm
Need the size of the fitting on the oil pump where the pressure line connect. Parts j of figure 180-25-5 of the shop manual page 180-25-4. Just stripped mine and im unshure of the dimension. Thanks
Re: Oil pump fitting size for pressure line 40c
Post by Jim B » Sat Feb 15, 2020 5:12 pm
Here is a link to the parts catalog open to the page with the hydraulic oil pump, which I think you are referring to. https://partscatalog.deere.com/jdrc/sid ... gId/278897
If this is correct I believe you are looking at item key # 14. That fitting is 3/8 Male NPT thread into the pump and 1/2" inverted flare female thread for the tube, I believe. With the part number someone can likely confirm that for you. Lavoy likely can help you with one if you need.
If you are looking at a different fitting you can scroll through the parts catalog, find it and post the part number.
Fredquebec
Post by Fredquebec » Sun Feb 16, 2020 5:47 am
Thanks thats exactly what i needed 😀
Post by Lavoy » Sun Feb 16, 2020 11:37 am
In stock.
Users browsing this forum: No registered users and 48 guests
