450C crawler bucket cylinder steel line AT31954
skunk237
Post by skunk237 » Mon Feb 03, 2020 3:28 pm
My 450 C loader developed a leak in the bucket cylinder line on the right side near where the line turns to go down the cylinder. I got a small hairline crack which shoot hydraulic out when I curl the bucket up. I cannot fine a line anywhere. JD says the line is obsolete, part number AT31954. My machine is a 1982, The crack is about an inch long. Anyone have an idea how to repair or where to buy a new steel line?
Thanks much.
God Bless America.
B Town
Re: 450C crawler bucket cylinder steel line AT31954
Post by B Town » Mon Feb 03, 2020 4:01 pm
Silver solder to fix it. That is the process used to attach the swivels to the ends of the solid pipes. I don’t have a used resource.
Best regards, Bruce
Post by Jim B » Mon Feb 03, 2020 4:42 pm
Bruce has a good, commonly used fix. I've also seen brazing, TIG, or MIG used, depending on processes available and skill levels. As for getting a new tube, one way would be if you can find an industrial hydraulic shop that deals in process tubing such as used in mills, power plants, etc.; they should be able to get the right tubing and ends to duplicate your tube. Sometimes hoses have been used to replace tubes, routing can be a pain. Good luck with it.
Jim
DrLoch
Post by DrLoch » Tue Feb 04, 2020 8:16 am
People/companies that build industrial hydraulic power units would be able to duplicate the line. Where are you located?
450C Track Loader
291457T
Post by Lavoy » Tue Feb 04, 2020 9:58 am
Take it off, clean it up, bronze it or silver solder.
skunk237
Post by skunk237 » Tue Feb 04, 2020 12:59 pm
Thanks much guys. I have some brazing rod and will check out the silver solder method. I can stick weld.
You guys always have the answers. I am so glad I found this message board and so many are willing to help a novice.
Have a great day and God Bless.
Lee
