1010 gas dozer
1010 gas dozer
Hi I have a 1969 jd 1010 dozer with a 4cylinder gas engine it turns over but will not spark. I put new points wires an plugs an a new condenser an ca not get it to spark any idea why it wont spark ??.
Re: 1010 gas dozer
Welcome to the board.
First thing, I believe the last 1010 was built in 1965 not 1969. Someone will speak up if I'm wrong on this. If you post you machine's serial number someone will be able to tell you the year.
Is this a machine you have had for a time and it just developed this problem? Or did you just get it in a non-running condition?
Was it running until you changed the points, condenser, wires, and plugs? Have you checked to see that the condenser wire or the point strap did not get grounded during installation?
Start by checking to see if you have 12+ volts to the coil and then power through the coil to the points. If no power at the coil work back from there to the switch, if no power at the switch keep chasing it back.
Is the battery fully charged so the starter is turning it over easily? If you had power at the points and coil, check to see how much the voltage to the coil drops while the engine is being cranked over with the starter. If it drops too much the starter draw may be too high. If the voltage only drops a little, try putting the old condenser back in. There have been many cases in recent years of bad condensers right out of the box, often when using generic aftermarket parts.
Jim
Jim
Re: 1010 gas dozer
Ok will try that thank you an yes battery is fully charged
- gregjo1948
Re: 1010 gas dozer
Just to add to Jim's procedure, be sure the distributor shaft is turning and the points are opening.
Users browsing this forum: No registered users and 214 guests
