1959 440 IC Engine
Crawly
1959 440 IC Engine
Post by Crawly » Mon Dec 30, 2019 2:35 pm
Spun a rod bearing or two on my 440IC...
Rod and cap journals will need cleaned up, crank turned, and while in there, I’d say maybe cylinders bored and all that jazz.
Had a local place quote me a running engine for $1750.
Anyone got perspective on what I’d be looking at rebuild cost wise vs. just buying the used engine...?
Crawly
Re: 1959 440 IC Engine
Post by Lavoy » Mon Dec 30, 2019 10:22 pm
My first comment is you have a used engine, why buy another one. It may be no different than yours, just hasn't spun the bearings yet.
My rough rule of thumb is $800 parts, $600 machining for a top to bottom correct rebuild. Does not include externals, on engine parts.
No piston available at this moment, but they are in process.
Crawly
Post by Crawly » Wed Jan 01, 2020 6:40 pm
Lavoy, appreciate the comment, makes sense. Thanks for the ballpark numbers too - helps me get feel for costs.
Crawly
Post by Lavoy » Wed Jan 01, 2020 9:45 pm
Rebuild yours, trust me, you won't believe the difference. I do mean rebuild, not hone and ring job.
Crawly
Post by Crawly » Thu Jan 02, 2020 8:20 pm
Yep that’s the direction I’m going to head...looking for engine shops in town. Will start getting everything lined up and jump in....I’m pumped
Crawly
Post by Lavoy » Fri Jan 03, 2020 8:14 am
If you need parts, let me know. I have some in stock, everything else is available except for pistons right now.
krob
Post by krob » Mon Jan 20, 2020 10:38 pm
Lavoy do you rebuild and machine engines are your place?
So could a guy ship you one is the question.
Thx
One good MC and several part machines.
Post by Lavoy » Tue Jan 21, 2020 6:46 am
Yes, done several, have one sitting here now from Alaska to rebuild. There are no pistons currently available, so it would be later this spring I am guessing before I could do one. Also, I do not do overhauls, I only do rebuilds, bored, crank turned, head rebuilt, etc.
Crawly
Post by Crawly » Mon Jul 06, 2020 5:28 pm
Hi Lavoy,
Wondering if pistons were available yet...
Thanks,
Crawly
Post by Lavoy » Tue Jul 07, 2020 7:13 am
Yes they are.
Users browsing this forum: No registered users and 44 guests
