jd440ic radiator fan
dtoots1
Post by dtoots1 » Sat Dec 28, 2019 11:27 am
well folks, blew a blade off the fan got radiator a bit will see if locals can repair that. don't know if good idea to weld blade back on or better get another? Lavoy, do you have any available? mite as well chck radiator hoses if you have them as well...need grommets for valve cover, will need 4 of them as same should fit my wheeled 40s, and need a new rad cap for he old 40s wheeled as well. if you have will call with card info Monday. would be nice if someone nearby had a fan, had one for diesel and sold it.dumb..tho think different?
Re: jd440ic radiator fan
Post by Lavoy » Sat Dec 28, 2019 3:37 pm
I have used fans on hand, should have new modern style 6 blade replacement on hand as well, if not, 2 day delay.
Lower hoses in stock for sure, normally keep upper on hand too. Thermostat and gasket?
Talk to you next week.
dtoots1
Post by dtoots1 » Sun Dec 29, 2019 9:07 am
is there a need of the 6 blade fan, does it run cooler? my 4 blade did seem to keep it cool enough. temp rises only when left idling a bit but does not overheat. Also what is price difference? should probably change thermostat and gasket while down anyhow
Post by Lavoy » Sun Dec 29, 2019 11:47 am
The 6 blade fan was an update from Deere, I've installed and sold many, seems to me $85. It is a modern design, twisted blade more balanced fan.
Used fan $40.
dtoots1
Post by dtoots1 » Tue Dec 31, 2019 12:27 pm
got rad back already, picked up just after 9 am.!!!!
Users browsing this forum: Google Adsense [Bot] and 261 guests
