1960 440 ICD Build
Zlkaser
1960 440 ICD Build
Post by Zlkaser » Sun Nov 10, 2019 11:34 pm
I picked up my first jd 440 icd about a year ago now amd started to redo it one step at a time! First thing was an engine overhaul due to it being locked up solid! Mine being equipped with a DD 2-53, i did new pistons, liners, turned the crank, rebuilt the blower, remaned the head, new injectors, etc, etc.
My question is on the undercarriage. Is the any parts still available for these either OE or aftermarket? (Chains, pads, rollers, etc.) or does it all have to be sourced good used parts? Any help or direction would be great!
1960 440 ICD
1964 2010c
Re: 1960 440 ICD Build
Post by Lavoy » Mon Nov 11, 2019 8:21 am
New 350 aftermarket rollers will fit, 350 chain will work if you rerim the sprockets, that is about it.
Zlkaser
Post by Zlkaser » Mon Nov 11, 2019 9:28 am
Ok good to know! I had read some of that in here, just wasnt 100% sure yet! What do you mean by rerim the sprocket? And what year range of 350 works for chains, rollers? Im assuming the older models
1960 440 ICD
1964 2010c
Post by Lavoy » Mon Nov 11, 2019 1:38 pm
You have to cut the rim of teeth off of your sprocket, and do the same with a 350 sprocket and then weld it back on your sprocket center.
All 350 are the same as far as pitch and bushing diameter.
Zlkaser
Post by Zlkaser » Mon Nov 11, 2019 4:21 pm
Ok i understand now, thanks for the help! I appreciate it! Now to start gathering parts!
1960 440 ICD
1964 2010c
gregjo1948
Post by gregjo1948 » Tue Nov 12, 2019 5:05 am
Seems like there is a small difference in the 440 rollers and the 350 rollers. I think something needs to be removed so they will bolt on. I just don't remember if the removal has to be done when installing the 350 rollers on to the 440 or the other way around. I'm sure you'll figure it out.
Post by Jim B » Tue Nov 12, 2019 6:24 am
This company advertises they make a weld on rim for 350 sprockets along with some others. Might be less expensive than cutting up new 350 sprockets. I don't have any knowledge of them beyond their website; maybe Lavoy or someone else has used their products.
http://www.hendersonmfgco.com/parts/par ... t_rims.htm
Post by Lavoy » Tue Nov 12, 2019 8:42 am
Absolutely spectacular product, best ones I have ever used, but over $200 each I think. Complete 350 sprockets can sometimes be found for $150.
Post by Jim B » Tue Nov 12, 2019 9:11 am
Thanks Lavoy. Good to know someone has had hands on them and they could be a viable option. Like most things now one should always check around. Prices and what is available vary almost day to day it seems.
Users browsing this forum: No registered users and 283 guests
