420 c loader crawler
Tuckersfarm
Post by Tuckersfarm » Sun Nov 10, 2019 6:03 pm
Put in a new clutch and adjusted it with tool worked for five times to dirt pile. Now it will not move back or forward the reverser is in gear ?
JimAnderson
Re: 420 c loader crawler
Post by JimAnderson » Sun Nov 10, 2019 6:39 pm
I take you are talking main clutch.If that is the case and you didn't notice any problems in the main drive shaft splines then you have other issues.
Reverser gears or bearings.These machines are over fifty years old and they can break in so many ways.You will have to find out what broke.
4 430C crawlers
1 40c 3 rollers
1 420c 5 roller
1 440c loader
1 430t tractors
1 IH H
1 3020 JDs
I Ford 3400 loaders
2 IH Cubs
6 WH GardenTractors
Post by Lavoy » Mon Nov 11, 2019 9:04 am
Need to determine if power is still going to trans, any noise like the trans is still spinning? Will it grind if you try to shift it with the clutch out? Shift reverser to forward and reverse, does it feel like it is shifting the reverser?
Tuckersfarm
Post by Tuckersfarm » Mon Nov 11, 2019 12:44 pm
Started the crawler last night it tracked to barn but steering clutches didn't want to work that well could it be steering clutches
Post by Lavoy » Mon Nov 11, 2019 1:37 pm
Yes, if both clutches slip at the same time, it will mimic a bad engine clutch.
Users browsing this forum: Google Adsense [Bot] and 21 guests
