450C Dozer 1974 Transmission Oil Concern
- davidblackburn1
- 40C crawler
I removed/replaced the filter in front of the radiator today. Oil was a milky yellow color. I saw that someone else on a different thread described the look of the oil as Latte (creamy?). I would say that is also what my oil looks like.
I have 10 gallons of new JD J20C oil and plan on draining the transmission and refilling with new oil. In the other posting it looked like it took 6 gallons to do this.
However on the other thread there was not a discussion on where the water came from? Is there something I should fix/plug major seal failure or ?
This is a new to our family machine. We have only had it a week.
I will try to post a picture of the oil when I can.
Thank you
Thank you
Cat D2 Hyster Winch, Blade added Retired.
John Deere 450C Dozer, Winch, ROPS. Burned up in fire in Sept 2020.
John Deere 550G Dozer, Winch, Fairlead, Mann Brush Rack, Rops with cage
Re: 450C Dozer 1974 Transmission Oil Concern
sea foam makes a hydraulic additive for moisture in oil have tried it and it works i also have a 450 C
JIM
JIM
Mikeforester
- 420 crawler
Most times the moisture problems are condensation related since most of these older machines get used sporadically. However, water has a way of sneaking in so checking for any loose bolts on the transmission covers can't hurt.
Since you're going to change the oil anyway, don't forget about cleaning the screen in the transmission housing (right side, 3 bolts, you'll need a new gasket), and if your machine is a true "C" model (check serial numbers) you have wet steering clutches that share sump oil with transmission, so change that oil as well. Add some seafoam with the new oil and it should help with any remaining moisture.
Good luck with old girl!
Mike
Mike
- davidblackburn1
- 40C crawler
Thank you, this information was very helpful. She is up on the timberland so this will be an in the field oil change in the pouring rain if I do it today. Any reason I cannot replace the gasket with Silicone (other than waiting 24 hours for it to cure?). I will have to wait more than 24 hours to get the gasket to do the task.
Serial number is 193326T. Looks like she is in the first batch of 450C. She has the Turbo Diesel. Looks like a day of studying her and figuring out location of all the drain plugs (I know where to look for transmission but not the wet steering clutches yet).
Is it the Sea Foam Trans Tune that I want? https://seafoamsales.com/product/trans- ... treatment/
Looks like it is for Car or Machine and one of the things it does is deal with moisture.
Last edited by davidblackburn1 on Sun Oct 20, 2019 8:41 am, edited 1 time in total.
Mikeforester
- 420 crawler
Clutch drains are pipe plugs at bottom of housing (one on each side), they go up into the clutch housing, not to be confused with drain plugs on the final drives (bottom of final drives going in towards sprockets).
I make my own gaskets when I'm in a pinch, but whatever works for you. I bought a couple of these gaskets to have on hand as they are pretty cheap.
If you don't have the manuals, check with Lavoy to see if he has any for your tractor. They come in real handy with these old machines.
Mike
Mike
the sea foam product i used was hydra tune for hydraulic oil the one you posted I believe is for auto trans fluid but there are mostly all the same
JIM
JIM
Permatex makes good sealer for when a gasket is not available. Any NAPA, Advance, ect. has it.
I had the same problem, with my transmission oil in my 450c dozer. Changed it last year and, now I discover the same thing again, milky looking fluid. And, yesterday I discovered that the water was likely coming from my clutch housing. I siphoned off a gallon or so of water from the clutch housing after removing the rubber plugs and working a small hose down in. I don't know how the water made its way in there but it has been parked outside for a few years. My problems are larger as the transmission fluid was also leaking into the clutch housing. I am assuming the water froze and did some damage to the transmission front cover. I will pull the engine in the spring and find out how bad it is. I drained the remaining transmission fluid and will put a pail of fresh fluid in so I can move it across the yard. Next summer I will get a shed built for my crawlers. I tried to get at the drain hole in the bottom of the clutch housing but it seems impossible to get at. If it gets above freezing again this winter (-10c now) I will take off the belly pan and then it should be easy to open up the drain hole. I have not used the dozer much in the past two years but regularly start it, charge the batteries and look it over. I was going to use it this week for a small one day job.
backhoe attachment.
backhoe attachment.
Users browsing this forum: No registered users and 138 guests
