9300 backhoe
tuney443
9300 backhoe
Post by tuney443 » Wed Oct 16, 2019 8:21 am
Does anyone have any idea on how to retrofit a diverter valve from an older 450 loader to make it work on a 450C dozer with 6 way blade? This is for adding on a 9300 hoe attachment.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
JWB Contracting
Re: 9300 backhoe
Post by JWB Contracting » Wed Oct 16, 2019 8:18 pm
I’m not sure if I’ve seen a loader with a diverter valve, normally a power beyond valve (screws into loader valve) would be used to allow simultaneous flow to both loader and hoe. The loader power beyond valve doesn’t fit a Dozer valve. We’ve installed hoes on both 350 and 450 dozers both with and without the diverter valve.
For a non diverter install we took the pressure line from the pump, ran it thru a relief valve with its own return to the tank, feed the hoe and then ran the hoe return to the dozer valve. That way we could set the hoe relief independent of the dozer, just enough pressure to allow pushing the dozer around with the hoe and we used the higher flow loader pump. An extra relief is necessary as the hoe doesn’t have one. Dozer was fast but manageable. This was on a widepad 450C.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 267 guests
