JD 40C final drive
mxc8099
JD 40C final drive
Post by mxc8099 » Sat Jun 29, 2019 9:13 am
Is there any place on the Internet where the JD part numbers for the final drive (that is the lower drive shaft that connects to the drive sprocket the track rides on) are listed as common part numbers such as Timkin or SKF numbers? chasing daown obscure JD bearing numbers is exausting and if found, very expensive
Re: JD 40C final drive
Post by Jim B » Sat Jun 29, 2019 9:26 am
Send Lavoy an email (postmaster@jdcrawlers.com). He will likely have the parts you need on hand. His business provides this site for us to use.
Post by Lavoy » Mon Jul 01, 2019 8:44 am
I normally have all of the bearings on hand.
Users browsing this forum: No registered users and 204 guests
