Final drive bearing kit available, 40-440
Post by Lavoy » Thu Mar 14, 2019 3:24 pm
New final drive bearing and seal kits for 4 roller 40 through most 440 up to 456,XXX serial number. Kit is $250 for ALL name brand parts, Timken or National bearings and races, OEM axle seal, and Timken or SKF pinion seal. This is not the import kit you see online with import bearings, poorer quality pinion seal, and non-OEM axle seal. There is NO correct aftermarket replacement for the OEM seal, ALL non-OEM axles seals will fail in a working crawler, period.
If you wish to purchase a lower quality kit, I can price that for you as well, guessing $100 cheaper give or take, but I do not stock them, so slight delay.
I also stock gasket sets, pinion and axle shims packs as well as the tool for installing the axle seal.
Users browsing this forum: No registered users and 0 guests
