JD 1010 crawler ID
JD 1010 crawler ID
I am looking at a 1010 dozer that appears to be smaller than the 1010 in my back yard. One of the differences is it has 4 rollers versus 5 rollers on the undercarriage of the one I have. Serial number is 1010 C 22041. Wondering what's up with that.
1959 440 icd 831 loader
1961 1010 dozer
1961 1010 dozer
- gregjo1948
Re: JD 1010 crawler ID
If you think it's an older model; count the engine cylinders. All the earlier models had 2 and the 1010s were all 4 cylinder.
Just looking at the parts catalog it appears they did make some 4 and 5 roller units. Track frame groups of both are shown. They show the 4 cylinder engines, gas and diesel, with the cylinder liner plate arrangement. They also had hydraulic track adjusters on the 1010s, I believe all the JD crawlers prior to this used screw adjusters. Others here will likely have hands on info.
5 roller was an option, 4 roller was standard.
Thanks for your replies. I am green with enlightenment.
1961 1010 dozer
1961 1010 dozer
In my experience, the 4 roller 1010's were much lower production than the 5 roller machines. Not rare by any means, just much, much less common.
Users browsing this forum: Google Adsense [Bot] and 234 guests
