Now available, 6/12 volt LED bulbs for MC-later 420 with individual bulb, $9. 430,440 wit bulb assembly, $47, flood or trapezoid available.
LED 6 & 12 volt bulbs now available
Re: LED 6 & 12 volt bulbs now available
Are the 6v LEDs much brighter than standard bulbs?
Don't have a crawler here to test them, but they have lots of LED bulbs per bulb, should be a whiter light as well.
OK. Do the 430-later ones come complete with housing? I'm running cheap aftermarket 6v lights now. I need to check if they have replaceable bulbs, but I'd prefer new light assemblies.
OK. Do the 430-later ones come complete with housing? I'm running cheap aftermarket 6v lights now. Need to check if they have replaceable bulbs, but would prefer new light assemblies.
No, just the bulb, I think I can still get the housings new, would have to check.
The early teardrop shaped complete lights are $50/each, you would just need to change the bulb.
The later rounded 430/440 complete are $45, Cree LED bulbs for them in trapezoid or flood are $45/each.
Users browsing this forum: No registered users and 0 guests
