350B Hydraulic Pump Shaft
jwiles58
Post by jwiles58 » Sun Sep 30, 2018 6:47 pm
Twisted the gear shaft stub off today and need to replace the gear shaft in the pump or rebuild the pump or buy a reman pump. Anyone know where to find parts? Thanks
cantbeatadeere
Re: 350B Hydraulic Pump Shaft
Post by cantbeatadeere » Sun Sep 30, 2018 7:21 pm
I had the same thing happen a year or so ago, the local JD dealer had the spline coupling in stock and my father who is a 33 year retiree of DEERE actually had a NOS pump in his toolshed (lucked out bigtime). the pump spline was shot on mine and I will assume yours is not much different so you will have to replace it as well.
1970- JD 2520, 1991- JD 400G long track, 2003- JD 4710, 2012- JD 1026R, 2014 Bobcat E42 long arm, 2016- 14ft dump trailer, 2017- 24ft 11,000lb hyd. tilt equipment trailer aaand 2018 ram 2500 Big Horn CUMMINS :D :D
DrLoch
Post by DrLoch » Mon Oct 01, 2018 6:36 am
You need to figure out out it twisted the pump shaft off as well or you will be doing that to the replacement as well.
450C Track Loader
291457T
Atnsolutions
Post by Atnsolutions » Fri Nov 09, 2018 9:47 am
Check your PM - I have a good used oem pump, with fittings and mounting lines, and part of the pump drive shaft adapter available. If you still need them.
