Starter solenoid
Nytrosledder
Starter solenoid
Post by Nytrosledder » Thu Sep 20, 2018 9:03 pm
Just wondering if there is a cross for the solenoid for a jd350 diesel. Hoping to be able to pick it up locally so I can is the machine this weekend. Thanks for the help!
Re: Starter solenoid
Post by Jim B » Fri Sep 21, 2018 4:34 am
That should not be a problem at any good parts store or electrical repair shop. I believe that at least the older model 350's used mostly Delco Remy starters that had the common 12 volt solenoid. See if you can get the number off the starter tag and they should be able to go from that. Check the JD parts catalog on line, they give the Delco numbers at times.
jsal
Post by jsal » Fri Sep 21, 2018 9:17 am
I have replaced two on different machines got them from JD not real pricy
Users browsing this forum: No registered users and 466 guests
