Engine help
Jason37756
Engine help
Post by Jason37756 » Fri Aug 31, 2018 6:19 pm
Went to start my 350 straight after a month of setting in the dry and she started right up at half throttle.
After about 5 seconds of what sounded normal I heard a dull thud sound and she died...upon trying to restart, the motor is very hard to turn over via the key and I hear a liquid sound coming from the exhaust...engine seems like it has too much compression and will turn slowly then just barely until the pressure is somewhat relieved.
Any thoughts?
gregjo1948
Re: Engine help
Post by gregjo1948 » Sat Sep 01, 2018 4:18 am
Did the head gasket fail? Check your coolant level and you engine oil for coolant.
Jason37756
Re: Engine help
Post by Jason37756 » Sat Sep 01, 2018 12:33 pm
Engine oil looks perfect...radiator is too low to see any coolant, I am unsure if it was like this when I parked it.
It ran like a top a month ago before I parked it. My current guess is hydro lock with a bad head gasket allowing coolant to leak into one cylinder.
Can I just remove an injector, check for coolant, and see if it cranks easier blowing out the coolant if there is any?
Jason37756
Re: Engine help
Post by Jason37756 » Sat Sep 01, 2018 5:03 pm
Solved!
Air intake full of water...filter rusted out.
Apparently water does take the path of least resistance. This time it was 4 weeks of rain leaking perfectly onto the ROPS and then draining into the intake housing.
The rusted out filter has no doubt been a work in progress over the years.
This will be a pre check before every job now.
Jason
Users browsing this forum: No registered users and 450 guests
