430 vs 40c engine
philga5
430 vs 40c engine
Post by philga5 » Thu Aug 09, 2018 7:43 pm
Hi, i recently found a 40c with cracked engine block and ++
seller also have a 430 tractor avail and I was wondering if 430 engine would fit in the 40c.
thanks !
tldec50
Re: 430 vs 40c engine
Post by tldec50 » Fri Aug 10, 2018 2:59 pm
I have a 420 engine in my 40c,had to change radiator to a 420 radiator,420 radiator bracket and throttle bracket that bolts to thermostat housing.every thing else is the same.A 430 tractor should have all that you need.Mine runs great but pulling engine to fix what broke in the clutch area.
philga5
Post by philga5 » Mon Aug 13, 2018 4:45 am
thanks alot!
RacinJason
Post by RacinJason » Tue Aug 28, 2018 2:50 pm
Just the opposite! I have a 40 engine in my 420C. Bell housing and engine mounts bolt up. I have a mickey moused 2 piece upper radiator hose to adapt the 420 (I think) radiator to the 40 engine. The 40 carb inlet OD is, I believe, 1/8" smaller than that of the air cleaner (or that of a 420C carb.) making the rubber elbow connector a bit difficult to connect. I had bought a new aftermarket connector for a 420, but it was so stiff, I used the old hose and used duct tape to replace the end that had been eaten away. If I am incorrect on this info, I'll gladly defer to the gurus. :-)
JD 112, JD 420 C
